voicemail-conf.xml information for Congstar Prepaid
  • Hello Support,
    Can you please provide the android voicemail-conf.xml information for Congstar Prepaid to be used for the 1-key speed dail?
    Source:
    <voicemail
    numeric="MCC+MNC"
    carrier="Operator Name"
    vmnumber="Voicemail Number"
    vmtag="Tag for Voicemail" />
    Example:
    <voicemail
    numeric="26303"
    carrier="E-Plus"
    vmnumber="+4 9 1 7 7 9 9 1 1 "
    vmtag="Voicemail" />
    Many thanks!
    Arnold Kaiser
  • Hello arkai1778,
    unfortunatelly I cannot provide the correct voicemail-conf.xml, but I'll try to sum up all information needed:
    • MCC: 262
    • MNC: 01
    • carrier should be "t-mobile"
    • The voicemail number depends on your phone number and the provider you had before congstar. You can find more details here (german only).
    • Please try vmtag="Voicemail" and let us know if this does not work.
    Regards
    Lars
  • Hello Lars,
    Thank you so much for the information.
    So if I get this correctly:
    Hello arkai1778,
    and I was with Blau before switching to Congstar, I'd chose the E-Plus option;
    Code
    +4 9-Vorwahl (ohne Null)-99-MyCellphoneNumber z.B. +4 9 1 7 7 -991234567
    Right?
    Regards,
    Arnold
  • Hello arkai1778,
    yes, if your number is still the same number you used then, it should be the "E-Plus" Option (the 99 in the middle).
    Regards,
    Ben
